How to package swap/exchange tomorrow
Stretch0890
Valued Contributor
Valued Contributor
Hi there!
I upgraded a week or so ago and my new phone is faulty so it’s being swapped out tomorrow (DPD is coming to drop off the replacement and pick up the faulty one). I forgot to ask on the phone when I spoke to 150 earlier, how do I need to package it up?
Do I just hand over the phone in the box it comes in and DPD will handle packaging, or should I package it like a normal parcel with bubble wrap and put it in a bigger box etc?
Thank you!
1 ACCEPTED SOLUTION
Leanne_T
Hi @Stretch0890
Thanks for coming here.
DPD will provide packaging when they arrive to exchange the phone.
Did our mobile care team advise what will be included in the replacement? Is this just the phone?
Leanne 🙂
Leanne_T
Hi @Stretch0890
Leanne 🙂
Hi Leanne,
Amazing thank you! Should just be the phone I think? I moved my eSIM over to another phone and was told to reset the faulty phone and put all the accessories back in the box.
Thank you for your help!
Leanne_T
Thanks @Stretch0890
If you are unsure about what is needed when DPD arrive, please give us a call on 150 the team can check what items are included for the exchange 🙂
