on 03-07-2022 03:34 PM
I took out the £10 roaming pass add on for a recent trip to Italy - I have a monthly pay SIM only contract. The instructions on stopping this on the website by texting STOP ROAMING PASS to 150 now that I’m back in the UK don’t seem to work as I’m just getting a text back which says my pass has been set up, not confirmation that this option has been removed
on 03-07-2022 04:52 PM
Try texting STOP ROAM FURTHER to 150.
on 03-07-2022 05:21 PM
Thanks for that advice - I’d tried this before and this is the txt message below that comes back - it doesn’t really confirm that the roaming pass is cancelled?
Hi Richard. Your device is set up to be used for roaming in any country.
If you'd like to restrict this to the EU only roaming (this also means you can't make international calls while in the UK) reply ROAM EU, but if you'd prefer to roam in the EU and to call anywhere when in the UK or EU, then reply ROAMEU INT
on 03-07-2022 06:00 PM
That's a reply to ROAMING to 150, not a reply to a STOP.
on 03-07-2022 07:53 PM
This is why I reported this as a bug as I did text STOP ROAM FURTHER to 150 and what I pasted is what came back as a reply
on 04-07-2022 07:49 AM
Hi @rhepneil.
If you're unable to remove the pass using the text method, I'd recommend contacting our Customer Care team.
They'll be able to help you to remove this.
Jon
on 24-09-2022 12:18 PM
Stop roaming
on 24-09-2022 12:22 PM
@Ako3 : Text STOP ROAMING PASS to 150.
