on 18-09-2022 11:50 AM
on 18-09-2022 11:51 AM
@Mandy2112 No such thing as the best device it’s what you want is best for you.
on 18-09-2022 11:55 AM
I made the switch from apple to android and never looked back. I'm currently using a Samsung galaxy s20 FE. I'm struggling now though to even place any kind of order with ee as it wants me to register a device or broadband & I have neither so now what do I do?
on 18-09-2022 12:04 PM
@Mandy2112 , you will need to log out and order as a new customer. If you have been with another network and want to keep your number, you will need a PAC code to transfer the number.
Are you wanting a contract or pay as you go?
on 18-09-2022 12:10 PM
I've tried the logout process multiple times and once I select what I want to order it requests login no other option so I'm at a loss. Was looking for pay monthly with 0 upfront if even possible but looks like I can't even get past the register page it gives me 3 options, add ee mobile, add ee broadband or join ee community
on 18-09-2022 12:41 PM
@Mandy2112 , I would suggest ringing customer service, they should be able to help. You also need to make sure you are doing this as a new customer, it should work, as you are not an EE customer. Try restarting your browser or try another browser.
on 18-09-2022 03:20 PM
@Mandy2112 : Is the Samsung Galaxy S20 FE with EE? If so, you should register its no.
