on 07-06-2023 03:16 AM
How/which add on can I get for texts in dubai
on 07-06-2023 09:22 AM
Hi @Jintyf
Welcome to the community. 🙂
You can see all costs relevant to the United Arab Emirates on our Roaming Tool.
Make sure you text ROAMING to 150 to make sure you're set up for roaming abroad.
on 03-10-2023 08:24 AM
All well and good - but because I have no network signal, I can’t send a text
on 03-10-2023 08:27 AM
Hi @Barmancy
If you have a pay monthly account, the text would need to be sent from the phone before travelling.
Did you activate roaming before leaving the UK?
Leanne 🙂
on 03-10-2023 09:05 AM
Your query is therefore different to that of the thread you've joined.
If you don't have coverage abroad then you have likely not got roaming activated - this is necessary to use your phone abroad. The process differs between pay-monthly & PAYG, which are you?
