Unable to activate TNT Sports inclusive extra
kaigammon
I have received the text message asking me to activate the extra however after entering my details and the one time pin I get the error
We are experiencing technical problems right now, please try again later.
I have tried multiple times and get the same thing. What may be causing this? I did have this as an inclusive extra in the past, does that have any bearing on it?
I managed to get this resolved in the end, I had to log into my BT account separately then access the activation link from EE within the same session.
After that it seemed to redirect me correctly to the discovery+ login page and activate the offer.
12 REPLIES 12
Northerner
Hi @kaigammon
Have you followed the guide.
https://ee.co.uk/help/tv-sport/getting-started/set-up-my-tnt-sports-subscription
Yes I have. As mentioned, at the final stage where I need to verify my EE account after I enter the one time PIN I get the error message in the original post.
Katie_J
Hello @kaigammon.
Welcome to the community.
Do you have a BT ID that has been set up with EE using BT Sport?
Katie
Yes I had that extra previously so would’ve set up a BT ID then.
Katie_J
Thanks for confirming @kaigammon.
Are you able to try activate using your BT ID HERE?
Katie
Unfortunately not, I get the message:
TNT Sports account not recognised
In order to gain access to discovery+ with your BT account you need to have an active subscription to TNT Sports.
Katie_J
Thanks for trying @kaigammon.
In this case I would recommend giving us a call and speaking with our technical care team on 150.
Katie
i have the same problem...
