Roaming pass across 2 billing periods
PM29
If I buy a roaming pass that starts in one billing period and ends in the next, do I only pay the £15 once?
1 ACCEPTED SOLUTION
Alex_M
Star Contributor
Star Contributor
You pay the full rate 🙂
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
7 REPLIES 7
Alex_M
Star Contributor
Star Contributor
Hi @PM29,
The roaming pass is initially charged pro-rata, and then monthly. For example, if you added it now, you would be charged pro-rate up until your next bill date. From that point onwards, you are charged the full £15 per month.
Would you be charged more than £15 for using it across two billing periods - yes, you will. £15 + pro-rate from when you added it.
In cases like this it might be cheaper to settle with the £2.29/day charge instead.
Thanks,
Alex
Thank you. And if I cancel before the second billing date do I pay the full month or pro-rata for the days used?
Alex_M
Star Contributor
Star Contributor
@PM29 : No, you will be charged for 2 billing periods, i.e. 2 x £15.
awits
@PM29 can you confirm you were only charged pro rata for the first period? There is direct contradiction from @Alex_M and @XRaySpeX
EE have nothing on their website to clarify either, and their wording is unclear. I can't find any specific terms for the add-on. If they do charge me the full rate twice in pretty sure it can be argued as they did not make the definition clear.
But if you can confirm either way that would be great!
@awits : See WHAT IS THE ROAM ABROAD PASS?
PM29
Yes. Pro rata for the days in first billing period and then £15 for second.
