Roaming in Spain and Portugal
Vin64
Hi I go away on the 29 th April and will be away most off may does anyone know if a roaming pass will be changed for 2 months or from 29th to 29th as 1 month thanks vin64
@Vin64   You are billed as per your billing cycle.  So are you billed on the. 29th as that would be 1 month if you didn’t stop it before the following month.  Remember you have to remove the add on also.
In the billing cycle you apply a roaming pass, it's applied immediately and charged pro-rata between that date and your bill date.
In the billing cycle you remove a roaming pass, it remains live & charged until your billing date at which point it's removed.
@Vin64 : Depends where your billing date falls during your trip.
The Roam Abroad Pass costs £25 per billing month from the billing month you order it (text ROAMING PASS to 150) until the billing month you cancel it (text STOP ROAMING PASS to 150). For all billing months during which you have the Pass it is charged at the full £25. However if the Pass is carried over from the 1st billing month to the next it will be charged pro-rata for that 1st month alone.
