Roaming Abroad Add On
Fitzy6465
I purchased/signed up for the Roaming abroad add on which should enable me to use my contract terms in the USA. However, since being here, I haven't been able to make any calls or text etc. Has anybody else had this issue? or is there a setting on the phone I need to do?
I have another mobile phone (EE Contract) enabled, which my wife uses and everything is fine with that one. Any ideas?
Northerner
Hi @Fitzy6465
There are many threads on this same issue. The add-on alone is not enough you need to enable roaming on your account.
Use Skype via WiFi and the number in my signature to contact EE (UK times).
Northerner
Hi @Fitzy6465
This is a recurring issue with many turning up here. Of course we never hear from those who go roaming swimmingly & everything goes as expected.
