ROAMING FURTHER PASS IN USA
SHL1
Hello
I have just bought a ROAM FURTHER PASS as I have moved from the UK to the USA and would like to retain my UK phone for some time before committing to buying a USA one.
Can I use it in completely the same way to access both UK AND USA calls?
In terms of connection - is it compromised or am I able to use USA network just as efficiently?
Thank you.
With the Roam Further Pass you may call & text UK, EU & US nos & receive calls from them. You are FUP limited on data to 50GB / billing month.
Remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
@SHL1  Remember roaming is meant only for 2 months out of any 4 month period and and longer and you could find yourself being charged for international calls/text.   If you keep your usage light you might be ok for awhile longer than 2 months.
That’s great! Thanks so much !
Cheers Chris. Yes, just trying to work out if it might be useful to retain a Uk number out here.
