NHS Perks
Hana123-
Two of my NHS perk discount codes don't work. Can I get help to make these work so that I can redeem them online?
James_B
EE Community Manager
Hi @Hana123-,
What happens when you try to use your discount codes?
Were you trying to use them with a plan that is already discounted?
11 REPLIES 11
DebbieLeigh75
Do you have HCA freebies
D.williams
Hi Debbie, I am not aware if I do.
James_B
Hi @Hana123-,
Hi James, it suggests the codes aren't recognised. I've had to generate all 5 of my yearly codes when speaking to your customer service team very recently and they advised to get in contact with the Perks team to let them know that 3 of the codes remain unredeemed and aren't being recognised on the system. They have identified which codes they are.
James_B
Hi @Hana123-,
What was the full error message you saw when trying to redeem the codes online?
Were you selecting the same device and plan when you were able to use a different code?
Hello James
I am not entirely sure of the exact wordings but it was something along the lines of the codes are not recognised. I then made a call to your customer service department and they confirmed the same. They tried all 3 codes (out of 5) too. We were attempting to use them against an upgrade. But, I still need the codes to be validated so that I can use them online as I have 3 lines in total under my account, another of which, is due an upgrade and would like to use a code then too when upgrading that particular number. Many thanks
James_B
I've sent you a private message @Hana123-
masumaakter07
I applied for perk code it’s nearby 23 days
but I am not getting it
Christopher_G
Hi @masumaakter07
You should be able to get access to your Perk codes through our EE Perk Portal.
