Issues activating/creating a Disovery Plus account via TNT Sports
B0ttinat0r
I've searched through the forum and have found quite a few users are having issues activating their Discovery Plus accounts but I couldn't see one which has the exact same issue as myself.
I've gone through the process of activating the account based on the links provided but I cannot login to Discovery Plus.
1. Navigated to https://www.bt.com/sport/activate-discovery-plus/
2. Logged into my BT Account.
3. I receive this message:
4. I click the "Go to discovery+" button and I'm redirected to the login page.
5. I try logging in with my BT credentials but this doesn't work.
I'm assuming I am supposed to create a Discovery Plus account at some point but I'm never prompted to do so. I spoke with the Discovery Plus support who made me create an account manually, but that didn't work. They then fobbed me off to BT and they couldn't help either. I'm now coming to EE hoping to get to the bottom of this.
Any help would be greatly appreciated!
9 REPLIES 9
James_B
EE Community Manager
Hi @B0ttinat0r,
Have you tried activating your subscription at ee.co.uk/tntsports?
Hi James!
The TNT Sports subscription is already active as I have been using it for while. I checked anyway just in case and it says I have nothing to activate. I checked my add ons and it has definitely been applied from that side.
Thanks!
James_B
Thanks for checking @B0ttinat0r
Please get in touch with Technical Support so a member of the team can take a quick look at your account.
They'll be happy to help. 🙂
Hi did you manage to get this issue fixed. I'm having the same issue
Katie_J
Hello @Yasknowz
Have you activated your subscription by visiting discovery+ on BT TV?
Katie
Hi
I am experiencing the same issue. Followed suggested link and get this
Christopher_G
Hi @JT116
Could you give it a try when not connected to WiFi please? Just to see if it works?
Thanks Chris for the suggestion but that has not worked either. Getting the same 'technical difficulties' response
Christopher_G
OK, thanks @JT116
It could be worth speaking with our technical support team to see if there's anything we can do from our side.
