22-08-2022 08:52 PM
I have been with EE for years and always had 20% BLC card duscount. Ive been due an upgrade since February but when I tried to do it today its saying the code is not valid? Any ideas? I want to get a new phone sorted for my hol but doesn’t seem right not to get the offer when its still showing available online? Thank you
23-08-2022 08:32 AM
Hi and welcome to the community, @BecP77. 🙂
Did you generate the code through the EE Perk Portal?
23-08-2022 09:37 AM
Hi, thank you. No it was from my BLC app, never used the perks portal before. Set it up last night, just waiting for my ID to be authorised. Should the code from there work? Going away at end of month so would like it set up by then.
23-08-2022 11:39 AM
Hi @BecP77,
Was the plan you were trying to order already discounted? The Perk discount is only applicable to full price plans.
23-08-2022 11:56 AM
Hi, no im due an upgrade so the discount would be on a full priced plan.
23-08-2022 12:25 PM
Please let us know if you see the same issue when using a code from the Perk portal @BecP77
23-08-2022 12:52 PM
Will do, just waiting for the perks account to be authorised to get it.
24-08-2022 06:18 AM
The perk code worked, had trouble with the website when processing order (took forever and frozen screen ) so had to go to the shop to complete it which wasnt ideal but sorted now. Thanks
24-08-2022 07:29 AM
Thanks for letting us know @BecP77
Leanne 🙂
