BT SPORT PS4
dpm77
Hi my BTSPORT app on my PS4 won't open. It just freezes on the opening screen then says can't connect. I have re-installed and re-started. App works on mobile on same network. Any ideas?
Thanks,
David
9 REPLIES 9
@dpm77   Are you playing for large screen access?   Is your BT subscription a smart benefit?
Hi @Chris_B yes pay separately as an add on to plan for large screen access - it's been fine for last few months - this only seems to have started happening over last few days
Leanne_T
Hi @dpm77
Does the app work on any other device apart from the mobile?
Speak soon 🙂
Hi @Leanne_T  thanks for the reply - I only have the PS4 app and mobile app - I don't currently have a PC or any other devices to try.
Thanks,
David
Leanne_T
No problem, thank you @dpm77
If you give us a call on 150, the team will get this looked into for you.
Thanks 🙂
dpm77
Thanks @Leanne_T - I did and they raised a ticket to say someone would get back to me - unfortunately they have just issued me with a new registration which might not be ready for 24 hours - this has kicked me out of the mobile app now so don't have anyway to watch the game tonight...
James_B
EE Community Manager
Hi @dpm77,
I'm sorry to hear you've had to set up a new registration.
I hope it's up and running very soon.
Thanks @James_B unfortunately still hasn't been activated
James_B
I'm sorry to hear that @dpm77
Please get in touch with technical support so the team can help.
