Activating inclusive extras
Kjaerligkatt
I’m looking to changing my plan, as I’m out of contract.  Before doing so, I need to check if I’ll be able to activate a selected  extra, as I cannot receive SMS from the device the SIM is installed in.
I live in a very rural location, with no viable wired broadband, and my Internet is provided through EE 4/5G.  This is achieved with the SIM fitted to a 5G Outdoor Router, mounted on a pole high on the roof for a good signal.  The SIM is therefore not easily accessible and the Outdoor Router is purely for data connectivity - it doesn’t support receiving voice calls or SMS messages.
What alternatives are there to activating an add-on/Extra if the SMS messages cannot be received on the device the SIM is fitted to?
Thanks in advance.
12 REPLIES 12
Hi @Matt_124 ,
It's a ZyXel NR7101, which has no support for accessing SMS or managing them via the GUI.  There is claimed to be a way to interact with the SMS subsystem using AT commands through the CLI, but this is only possible with root or supervisor login, which is not provided.
Michael_D
There are some data only SIMs available on our website @Kjaerligkatt. You can see the option on this link.
Some of the plans do mention inclusive extras, but it would be a similar position to activate them where you'd either need access to the SIM or have options to view the text another way as @Matt_124 mentioned.
The only thing with ordering from that link is that it would be as a new contract, and therefor a new SIM. The other option would be to speak to our upgrades team to see what they can do on the existing SIM for you.
Michael
Thank you @Michael_D .
I think I'll have to speak with the upgrade team - those data SIMs you linked say they are limited to 100mbps speeds, which is significantly less than I get now.  Having to replace the SIM is also not ideal, as I'll need to go up a ladder to switch it - something I wouldn't want to do until the better Spring weather arrives.
It shouldn't be this difficult to renew a plan 😀 (no criticism intended, was just hoping this could be done easily and quickly online)
