do I need roaming to use wifi abroad?
chrisf888
what is the best way to use my phone in costa rica?
do I buy a EE roaming addon or purchase a sim in costa rica?
what is required just to use wifi?
@chrisf888   you can use Wi-Fi has much as you like EE don’t charge you for Wi-Fi.   Using cellular data, phone calls. texts will cost you.
Text RO Costa Rica to 150 see what you can purchase in order to use your device away from Wi-Fi.
you also need to enable roaming on your EE account so you can connect to a local network. To do this just text ROAMING to 150. having roaming enabled on your account is free.
Not only does EE not charge you for using WiFi on your phone, it has nowt to do with them. They only provide the mobile network.
WiFi is just a wireless connection between a mobile device and a broadband router. Totally separate from a mobile network connection.
