data
linzi841
am in the usa just now with work i cant now get my data to work, i have loads and the roam pass to can any one help
@linzi841 : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
