data
samjohnstone_0
i'm abroad and my roaming is on but my data won't work. i've already turnt my phone on and off.
@samjohnstone_0  Is that roaming enabled on your EE account?
@samjohnstone_0 : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
