Working overseas in Norway with no network connection
Stevesbikesuk
Hi I'm in Norway  trying to contact EE to find out why my phone has no network
@Stevesbikesuk : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
