Wifi calling issue on wifi
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎06-07-2022 03:05 AM
OK it's a multi part question. The other week when mobile services went wonky and despite EE saying this was only a mobile issue my wifi calling went off at home. I have no EE signal at home so make wifi calls using wifi from my router. But like a said when the mobile fault happend 2 or 3 weeks ago no wifi calling on Broadband.
Yesterday exactly the same issue. Come home no wifi calling spent 1 hour 20 on phone (landline) with tech support my mobile was fine my Broadband fine wifi was fine just no wifi calling available.
So at roughly 7pm my phone started receiving texts and as if by magic wifi calling had returned.
So my main question is what actually makes wifi calling work ? Over wifi ie when you have zero network signal and rely on wifi. What magic makes it work
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎06-07-2022 09:15 AM
Hi @kcurrie65,
A support ticket was raised yesterday afternoon when it was identified that a small number of customers were unable to use WiFi Calling and the issue was resolved later that evening.
We're sorry for any inconvenience caused.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎06-07-2022 08:24 AM
Hi @kcurrie65,
I'm happy to hear your WiFi Calling service is back up and running.
There's a lot that goes on in the background to make your WiFi Calling service work, but essentially, it just sends and receives the information needed to make your call into the EE network via your broadband connection, rather than over the air using your mobile signal.
Hope this helps.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎06-07-2022 08:48 AM
I guessed there is more to it than just a wifi connection. So when wifi is on and wifi calling fails then its a network issue ? That apparently dosent show on EE systems ?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
Hi @kcurrie65,
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎06-07-2022 09:42 AM
Agreed it was resolved very quickly hats off to that. I think though. Thinking out loud here. When you spend as long on the phone to support and despite my best efforts explaining to them wifi calling was available when I connected to my vans wifi on o2 and that at work wifi calling was fine on both phones mobile support thought both were faulty at same time? Chances of that ? I am happy that I wasn't crazy after all though and for the quick fix thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎07-07-2022 08:26 PM
Hi James,
I am still experiencing the issue with wifi calling not working despite the fix being put in place as you say. As with other customers, I live in a rural area with no signal at all so rely entirely on wifi calling to make calls, especially since the removal of the booster service previously offered by EE.
Are any setting adjustments required on the device side to rectify the issue?
Thanks,
Rich
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎07-07-2022 08:31 PM
Have you tried restarting your phone and also toggling WiFi-calling off/on in your phone's settings?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎07-07-2022 09:03 PM
What colour is your hub ? Black or white ? I had initially a black one and it would not allow wifi calling amongst many other issues. Its also a known issue
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎07-07-2022 09:06 PM
So my camper has an o2 mifi. Turn it on and boom wifi calls appeard this issue I had no restarts or hub resets would fix. They did find a fault on their network was not a phone or hub issue for me on this occasion
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎08-07-2022 12:03 PM
Hi there,
yes, I’ve restarted the phone, reset network settings etc. I work in IT so have done the usual but to no avail.
Cheers
Rich
- Having issues connecting to EE hotspot and text code in Mobile Network discussions
- Repeat issues with mast which covers TA6 in Mobile Network discussions
- Wifi calling people unable to hear me in Mobile Services
- 4g ee payg the worst network I ever used in Mobile Network discussions
- USA Calling issues in Roaming
