Roaming data
MinoshkaVaz
I am in Croatia, My EE auto activated a £2 per day plan to use my minutes and data and it was working fine when I turned on my roaming data. But overnight it stopped working and I have tried interchanging the setting but it doesn’t seem to get back on. It shows a 4g and is on auto network provider signal. Not sure why its not working, tried restarting the phone too but no luck !! Please help , cant be in a foreign country without data 😞
@MinoshkaVaz   Have you tried manually searching for a network?      It’s not your EE account at fault if it was working.
@MinoshkaVaz : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
