Voicemail
AB2024
Can anyone help. I keep getting voicemail notifications but I don't and have never had voicemail turned on. Every time I ring the number there's nothing there. But I am getting multiple notifications a day. It's driving me insane.
@AB2024  turn on your voicemail by texting VM ON to 150, then call your device and leave yourself a voicemail. Then from your device call your voicemail and listen to the voicemail you’ve just left then delete that voicemail. This should clear any notifications that you’ve got. If you then wish to turn off your voicemail. Text VM OFF  to 150
