Voicemail
LiamGray88
when people try to call me it goes straight to voicemail. It’s not an issue with the phone because I’ve tried it on  a different handset. I’ve checked my software and do not disturb is off as well as well as airplane mode is off. Could you please advise. Thanks
@LiamGray88  If you’ve called yourself from a different handset and it works as it should then the only issue can be a lack of signal when someone calls you as this would go straight to voicemail.    By any chance have you blocked anyone from calling you ?
