Voicemail notification
margaretm1955
Cant clear voicemail notification
Get someone to leave you a VM, listen to it, delete it, reboot. Does that clear it?
Doesn't work
@Dgrey   Leave a voicemail then listen to that voicemail in full then delete it,  this should clear the notification.     You need to leave at least a 10s voicemail message.  You also need to listen to it in full.  You’ll then get opinions on what to do with that voicemail .
