09-04-2025
10:51 PM
- last edited on
09-04-2025
11:19 PM
MikeT
I am having similar issues. I am 1) being notified of voicemails, 2) sometimes able to access the voicemail message function to retrieve them (i think that's an international.network issue), 3) but when listening to them the system won't accept numerical commands from my phone, ie "2 to save, 3 to delete"- so i can't move past the first voicemail message. The phone is new-S25 plus, so that's not the issue. Also it's only happened in the country i am in now. Not previous countries.
09-04-2025 10:57 PM
Post moved to a new thread. Can you use other IVR-based menu systems, or is this EE-voicemail-specific?
Can you manually select another local network in your host country, does the same issue persist?
Which country are you in, and which networks does this affect?
09-04-2025 11:04 PM
I am in Fiji. I have a Fj Vodafone sim and sim 2. The FJ network works fine for most things but it seems to not be able to support accessing ee voicemails. I have used the ee sim to call voicemail.
Sorry I don't know what IVR is? The problem i have is solely related to voicemail. I can use the phone for all other things...internet access, calls in fiji and abroad (on the fiji sim), social media etc.
09-04-2025 11:10 PM
IVR means "Interactive Voice Response", but is basically any automated phone system where you press 1 for this, press 2 for that, press 3 for something else.
I'm enquiring as to whether you can use other IVR systems on your current network. Or indeed whether you can access EE voicemail when using another Fiji network.
09-04-2025 11:30 PM
I haven't needed to use IVR for anything else. Not needed to call any other companies with "press 1 for this, 2 for that"
09-04-2025 11:50 PM
And my other question? There's 2 networks in Fiji - does this happen on both?
10-04-2025 02:00 AM
I haven"t used Digicel. My ee sim choices vodafone Fiji, and my second sim is vodafone fiji in any case.
10-04-2025 02:02 AM
I suppose my general point is. It was working fine in Australia and NZ. I can accept there maybe network capacity issues in Fiji, ie difficulties connecting. I think that is routine even in Fiji. It's just understanding why it's an issue now.
10-04-2025 08:41 AM
Use your phone's manual network search to try.
FYI you have a short time after posting to edit, negating the need for multiple short replies.
