Using phone abroad
Naida1
Hi
I recently went on holiday to Spain and received no text messages from EE on arrival in the country, in fact received no contact at all.  I could only access my device for phones, texts and whatsapp if I was connected to WiFI.  This hasn't happened previously.  Can you explain why this happened and if there's anything I need to do to correct it?
Naida1
Christopher_G
Hi @Naida1 and @adam_scott7
Please both text ROAMING to 150. This will make sure your phone is set up for international roaming, The 'welcome' message is triggered when your phone connects to a network outside of the UK. Since you didn't get one, it is probably down to your phone not connecting.
Please take a look at our roaming costs page as well, so that you know what to expect when you get there.
9 REPLIES 9
adam_scott7
I go to Portugal next week and was wondering if I needed to do anything with my phone to make it work while I'm over there
Christopher_G
To add to this, if you don't enable international roaming before leaving the UK, your phone won't connect to foreign networks.
That will cause a catch-22 situation and leave you off-service unless you contact CS by other means.
Thanks so much for this, EE have now confirmed my phone is enabled.
Thanks for your help
Naida
James_B
EE Community Manager
No problem @Naida1 🙂
Hi Chris we are currently in Greece and I set up roaming on my sons phone back in the uk but since arriving my son has no phone or internet his phone won’t connect to any local network
Christopher_G
Hi @Gisbo70
Could you try manually searching for a Greek network provider in your son's phone settings?
I am already in Madeira. Before I left I text roaming but now I have arrived I have no signal is there anything I can do to rectify this?
Katie_J
Hello @bluedawg.
Did you text ROAMING to 150? or did you purchase a roaming pass?
Have you tried manually connecting to another available network?
Speak soon,
Katie
