Using my phone in New Zealand
Awizzbang
Have just arrived in NZ and had purchased a 1 month roaming, but when I try to use my phone there is no signal from any of the companies here, have I done something wrong
@Awizzbang  You purchased a roaming add on that keeps costs down you haven’t purchased roaming as this isn’t a chargeable feature it’s an option that you choose to use.   You setup roaming by texting ROAM to 150 or you call customer service to have roaming enabled on your account.  This is usually done before you leave the UK.
Once customer service opens today you could use live chat via the my EE app to speak with customer service to request roaming be enabled on your account.  Make sure you state where you are,   As there is EU only roaming and then there’s global roaming
just to check have you tried restarting the device since you got there ?  Have you tried a manual network search?
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
Awizzbang
The biggest problem is trying to get through to EE customer service given that NZ is 13 hours ahead of uk but replies have been useful
