on 10-09-2023 12:53 PM
Can I use my mobile in Turkey?
Solved! Go to Solution.
30-11-2023 08:50 PM - edited 30-11-2023 09:02 PM
EE’s Quality is certainly not something to bring to the table, it’s pretty dismal compared to BT Mobile, of which I only switched from due to them promising to match the service having become part of the BT Group. EE certainly has some ground to make up to compare even slightly. Not even yet mentioned the signal issues and lack of compared to BT/Giffgaff.
on 30-11-2023 08:54 PM
They charge you to operate in the E.U pal, 80% of other networks are free, they charged me £2.29 per day, my partners Giffgaff was free, my sons BT mobile, also free.
Like I said, EE has a long way to go!
30-11-2023 09:02 PM - edited 30-11-2023 09:03 PM
@L33MUA : Off-topic! OK, now let's get into a argy-bargy about EU roaming when up to now we've been discussing Turkey where you have been proven blatantly wrong! Not your pal!
on 30-11-2023 10:53 PM
on 11-08-2024 10:37 PM
Absolutely, you willing to pay for my time considering you’re too lazy to do your own leg work.
on 11-08-2024 10:44 PM
Quick answer is YES you can use your EE phone in Turkey, but it’s going to cost you a lot, easy option is-
Your EE device is open all networks, many uk providers are A LOT cheaper, I have two numbers running concurrently on my iPhone 14, one EE and one GiffGaff, these run side by side without issue’s, EE is eSIM, GiffGaff is in the sim tray…. I now turn the EE Sim Off when holidaying as the basic roaming charges are a rip off, giffgaff doesn’t charge you for E.U Roaming, plus it’s cheaper to use in turkey.
Or, buy a SIM card on holiday and divert your normal number to the temporary one.
