Urgent help needed - data abroad
Sanaindaclub
I travel a lot to Europe and Asia and have all the travel stuff set up. I have 6 lines with EE and hence also get some perks when travelling
we are in the UAE and I’ve had the usual texts to say we have landed and are in UAE and here’s how to add data and charges etc.
we have connected to Etisalat and data roaming is on
however I can’t add it! I can’t text or call out, with our without dial assist/manual codes. Nothing. At all.
I can’t call EE via 150 or the freephone numbers as the issue won’t let me call anyone
I can’t text travel to 150 as it bounces back and when I follow the link on data it just shows my usual allowance not the travel page with the option of buying data!
im with my two young kids and need data so the issue is urgent.
Can someone help!!
Leanne_T
Hi @Sanaindaclub
Thanks for coming here.
Can you try manually connecting to a network in your phone settings?
Thanks 🙂
@Sanaindaclub : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
