Unable to get signal in greece
Domclarke
Hi. I'm currently in Crete and my phone hasn't connected to any network although i have roaming enabled. I didn't text roaming to 150 before I left and now I don't have signal to be able to message or call. Could someone please help me sort this asap?
@Domclarke : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Having a roaming add-on doesn't of itself activate roaming on your a/c.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything.
