Unable to call EE from Thailand
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-07-2024 08:55 AM
Hi, I’ve stupidly travelled to Thailand without informing EE (which turns out to be way more hassle than you’d think). I brought a Thai sim like most others do when here but there is a block on other sims as the phone is an EE device. When trying to call them nothing gets through, I just get a automated Thai message then I’m automatically disconnected.
Not sure how I can go about this. If I cannot contact EE how am I supposed to resolve this?
Any advice would be much appreciated.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-07-2024 09:00 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-07-2024 09:00 AM
