on 26-11-2022 03:41 AM
issues holding network in US. Roaming shows as on.
move used abroad many times
holds the network for 1 minute then goes to sOS
everything I read says text 150 but texts won’t deliver even on Wi-Fi. Can’t call either as no service
not sure what my options are
tried resetting
usually shocking issues with EE
on 26-11-2022 06:00 AM
@Gs2079 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 26-11-2022 10:42 AM
Can you confirm that you mean the "international roaming" & "call abroad & premium rate" options are showing active in your myEE, as mentioned by the previous reply?
There's been many issues posted lately regarding VoLTE roaming in the US, but these are as much for the local US networks to resolve.
