Trying to use mobile abroad
Cjd-3
My sons phone is connected to my bill, he’s in Spain I had parental setting off for roaming, I’ve now switch it on, but he says he still can’t use his phone abroad can you help please
Are he on contract or PAYG? Did he use that SIM for making calls or texts in UK before he left to go abroad?
If he is on contract, did he activate roaming on his EE a/c before he left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts
Leanne_T
Morning @Cjd-3
Thanks for coming here 🙂
Has he tried restarting the phone?
This can take up to 24 hours to fully activate once the roaming settings are set up.
Let me know how he is getting on 🙂
