on 14-10-2024 06:04 PM
Dear all
When I am trying to send a picture to an RCS device. I get a message sent failure. What am I doing wrong? The picture is definitely going to RCS enabled device as I can see RCS in message field. Hope you can help. Thanks a bunch!
Solved! Go to Solution.
on 16-10-2024 06:34 PM
Well… I toggled rcs on and off. And it works. Sent a picture just now and it is marked as delivered. Thanks guys!!!!
on 15-10-2024 09:17 AM
Hi @Androidvim
Thanks for coming to the community!
Are all other messages sending OK without an error?
Do you have MMS Messaging enabled in your iOS settings (Settings>Messages>MMS Messaging)?
Is your device up to date with the latest software updates?
Linzi
on 16-10-2024 06:20 AM
Thank you for replying! No MMS is not enabled and all other sms and iMessages send ok.
on 16-10-2024 06:21 AM
I have no MMS bundle.
on 16-10-2024 10:17 AM
Thanks for confirming that for us, @Androidvim.
What iOS version is it you're using at the moment, and are you fully up to date?
Also do you know what make and model of phone it is you're sending to?
Peter
on 16-10-2024 12:58 PM
Fully up to date with latest iOS version. And I have no clue what type of phone it is when trying to send. All I know is that there is RCS in the message field.
thabks for getting back to me.
on 16-10-2024 01:55 PM
Nice one, cheers @Androidvim.
If you go to Settings > Apps > Messages, does it show that RCS is enabled here?
Also if you go to Settings > General > About > Scroll to Physical SIM > Tap Network provider > does this change to 'IMS Status' and show 'Voice, SMS & RCS'?
Peter
on 16-10-2024 06:31 PM
Thanks again for replying and taking the time. Yes to all.
on 16-10-2024 06:36 PM
Thanks @Androidvim, I'm really glad to hear this did the trick.
Sometimes it's the simplest steps that do the job 😉
Thanks for coming back to let us know too!
Peter
