Texts
MrDental
For some reason I can't text, I can receive but I can't send. Anyone experiencing problems
@MrDental : For sending texts, check your phone's Messaging app has the Message Centre no. setting for EE as +447958879879.
MrDental
Thank you for the reply and I did check the settings and they're correct 👍🏾
Christopher_G
What happens when you try to send one, @MrDental?
Are you able to make calls?
