‎30-10-2022 01:29 PM
My Iphone 13 (Mini) is intermittently taking ages to ring out. It just says 'calling' for up to 30 seconds before anything happens, if at all, even on wi-fi. Any ideas what to try?
‎30-10-2022 01:41 PM
@WHEELCHIMP Try a network reset on the device. You’ll find this in Settings>General>Transfer & Reset iPhone>Reset> and then select Reset Network Settings. You will have to put back your Wi-Fi password on the device as this resets all network connections not just cellular.
