09-10-2021 04:21 PM
I have a basic mobile supplied by EE about 3 years ago. It seems to work fine, but I think texts from my surgery have not been delivered to me - they insist that at least one was sent, but I cannot find it on my phone.
Is there any way you can check that it was received by EE? I can supply the time it is said to have been sent.
Regards,
Philip Bolt
09-10-2021 07:31 PM
Hi @moleonemail
EE would not be able to tell you this I'm afraid.
You would need to check with your GP the number they have is correct.
09-10-2021 07:37 PM
Are you receiving text messages from other senders ok?
10-10-2021 12:34 PM
Hi Bristolian,
Yes, I get things from EE, the NHS covid test stuff and junk from various. The surgery one was important - about the second covid jab - which I missed.
10-10-2021 01:47 PM
Hi @moleonemail
I am sorry we have no way to check incoming texts.
If you get all other text messages, I would suggest speaking to them again.
10-10-2021 05:18 PM
Thanks, Leanne_T. I'll use your statement if you don't mind.
Regards
PB
10-10-2021 07:03 PM
