Texts and calls not happening in UAE even with roaming add on
Qgh
Hi
i have the roaming package but nothing is working except emails using hotel wifi.  No texts, messages or calls in or out.  I’m now being charged for something that either wouldn’t work anyway or isn’t working for a reason.
anyone any clue or we can you help as I can’t text or phone you…….!!!!!
Schockwave
Hello @Qgh ,
Welcome to the community,
Are you on contract or pay as you go?
If on contract, did you enable roaming on your account? No need to do this if on pay as you go, as this is auto enabled.
You will have to ring customer service to get roaming enabled if on contract, see my signature of ways to ring customer service.
Do you have a signal? If you have enabled roaming on your account, then try turning phone off and on, look manually for a signal to see if there is one.
Just buying a roaming package, does not enable roaming, you need roaming enabled on your account.
