Technical help
Libbybet
Hi there,
Can anyone please help? I cannot use the internet or make phonecalls from my phone. All bills are up-to-date. I can send and receive texts but that's all. How can i access help with this, as i cannot use my phone to call the technical help number? Nor do i have another phone to call from at present.
Thankyou!
Alex_M
Star Contributor
Star Contributor
Hi @Libbybet
Do you get any kind of tone or anything when you call out?
I'd recommend checking for problems in your area using the Network & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status'.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
