Spend cap
elma1
I am abroad at the moment and cannot make calls, I think it is due to spend cap, but I can't work out how to increase my spend cap.  I tried texting 150 but it didnt work
@elma1 : Where are you? You only think it's your Spend Cap. What reason have you for thinking that? There are many reason for roaming not working more often than Spend Caps.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
James_B
EE Community Manager
Hi @elma1,
To manage your spend cap, login to My EE and select Manage my device from the Controls tab.
Hope this helps.
