Roaming
Anthonybennett
Hi ive added the roaming pass to my contract as im abroad in portugal, but its not working it wont let me send texts.
Does anyone have an idea why this is happening
@Anthonybennett : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
