Spain
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-03-2024 07:43 PM
Why can't I call the UK from spain
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-03-2024 08:07 PM
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-03-2024 08:28 PM
Does your phone show a connection to any Spanish mobile networks? That's needed to make or receive calls, send or receive text messages or use mobile data.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-03-2024 07:21 PM
Can't remember if I activated roaming before I left and have tried manually selecting a Spanish network and tried calling cs but can't call so none of the above worked
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-03-2024 07:35 PM
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
- Abroad With EE Son Can't Buy Pass On Website Unlike Me in Roaming
- Currently abroad (Majorca) and cannot make any sense of roaming charges in Roaming
- HAS MY GALAXY 24 PLUS GOT FREE ROAMING TO SPAIN in Roaming
- Why do I need £20 spend cap to use my contract aboard? in Roaming
- Why can i txt roaming while in spain, i carnt activate my roaming so incure char in Roaming
