SOS
Rebeccacaveney
I am currently on holiday in USA I have the roaming benefit add on included in my package. My service is on SOS I can’t call or do anything. Any ideas how I can fix this? I have already tried manual selecting a network and automatically selecting one
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
Thank you I will try calling
