Re: Unable to receive calls or texts abroad
Charlie0405
I am having this issue at the moment. Did yours get resolved and if so, how? Thank you.
Charlie0405
I can make calls though, so connection is working.
I have tried:
  • network reset
  • Turning price cap off
  • manually joining different networks
  • software update
James_B
EE Community Manager
Welcome to the EE Community, @Charlie0405 🙂
What does the caller experience when trying to call you?
Does it affect all callers?
Hi James
Thanks for your reply! Yes it affects all callers. It says ‘this phone is currently unavailable’. Sometimes it will also give a message in Maldivian (I am in the Maldives).
Many thanks
Charlie.
Everything here points at a local network issue. The only thing you can do is to try alternative local operators, EE may be able to raise a case for further local investigation if you contact CS.
Thank you. I’ve tried this and have raised with EE but no luck! Thank you anyway, much appreciated.
Charlie.
