Roaming
Lisajrose
I set up roaming before I left but it hasn’t been applied
@Lisajrose   How did you actually do this ?    Did you purchase an add on or did you text ROAMING to 150 ?  Purchasing add ons doesn’t enable roaming it’s just an add on to keep costs down.
@Lisajrose : What's this roaming you set up? There are many roaming things you can set up, the principal ones being activating the roaming ability on your a/c, which is paramount, & buying a roaming billing add-on to help pay your bills whilst abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
And what makes you think "it" hasn't been applied?
What is the actual problem you have? Does your phone show network coverage?
Silcrows
I recently came back from holiday. I had a similar issue where I had a spending cap which I increased. I got through to EE who said that it wouldn’t work right away and removed the spending cap which sorted it
