Roaming
jj3000
Good day everyone, can someone tell me how to switch roaming on and off easily? I live in SW Scotland and in some places phone automatically connects to Isle of Man and charges roaming fees when I'm not there! Thanks
Northerner
Hi @jj3000
What device do you have as you can disable roaming on your device.
You may need to contact CS on 150 to request this, there doesn't appear to be an option on the text service.
The alternative is to disable data roaming in your phone's menu, and take one of two courses of action for voice calls & texts:
1: Use manual network selection to only use UK-EE, this may cause issues re-selecting coverage that you've lost
2: Rely on the "welcome to IOM" automated texts, and check you're on the UK network before making calls or sending texts. You can mitigate this, and incoming call costs, by having a zero spend cap.
Thanks Northerner - it's the Samsung A14
Thanks Bristolian, I guess that would work. I was really after an 'easy' way but don't think it's possible. Will probably do as you suggest.
I do get welcome to IOM texts but don't always notice them straightaway. Bit of a pain really, will try CS and see if they can refund the charges as can prove not out of Scotland using GPS records at time of roaming.
Just discovered zero spend cap - will initiate that, thanks
