Roaming
Leila87
Can’t get roaming in USA
@Leila87 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
You've not said, but I would assume "can't get roaming" means you have no local network connection in the US?
Did you receive a welcome text message on arrival abroad?
Are you on PAYG or pay-monthly? If on PAYG, did you use your phone in the UK before leaving? If on pay-monthly, did you enable roaming by texting ROAMING to 150 before leaving the UK?
If your symptoms are something else, please explain.
