on 01-11-2023 03:07 AM
Is there any way I can check what is going on with my roaming as I have just landed in Singapore and my network is not automatically connecting and the EE app is down for me to log in? Can anyone help or advise please? Thanks in advance
on 01-11-2023 04:03 AM
@Robbie1103 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 01-11-2023 08:41 AM
A phone not connecting to foreign networks is symptomatic of roaming not being activated.
