21-06-2023 09:24 AM
Hello,
for travelling to which countries do you not need to activate roaming?
21-06-2023 09:32 AM
The UK only.
21-06-2023 09:32 AM
The UK only.
15-08-2023 04:54 PM
TENEREIFE
15-08-2023 04:57 PM
@Puddleduck1 : Yes, for there you do if you are on contract.
15-08-2023 04:58 PM
Roaming means using your phone abroad.
If you are in the UK on EE's network you are not roaming
If you are travelling outside the UK where EE doesn't provide coverage, you will need to activate roaming.
