Roaming
Julie162
Am travelling to the USA and I want to be able to recieve calls... how much does it cost?
@Julie162 : As it is not in EU, if you are on contract, you may use your usual UK allowances there with up to 50 GB data per billing month if you have more, when you buy for £11.40 / month or have already as a Smart Benefit the Roam Abroad Pass or you have an EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/usa.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
Kirigaya_Kazuto
Star Contributor
Star Contributor
You can check that here: Roaming Costs | Help | EE
