Roaming
garry50
Hi,I am going to Madeira  end of August,when I type in Madeira  to check if its covered by the roaming pass it says it does not know where this is,so does Madeira  come under Portugal?
@garry50 : Madeira is in Portugal.
You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £11.40 / month charged pro-rata. There are no extra roaming charges for PAYG.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
